A special Mitutoyo Litematic Promotion delivers a 10% discount on several different types of Mitutoyo Litematic Units and vacuum package add-ons until December 13, 2024. Use this opportunity to save on some of the most trusted and accurate battery foil thickness measurement instruments on the market.
After reviewing the 2024 Litematic promotion, if you would like further information or have any questions, please complete the form located to the right. One of our experienced specialist will reach out to provide you with personalized assistance and support.
Litematic Foil Thickness Units
The Mitutoyo Litematic Contact Gage provides constant measuring for high-accuracy inspections of many different types of workpieces, most notably battery foil thickness and other similar materials. The Litematic is available in the standard- and low-force models.
Vacuum Add-on Packages
When using a Litematic to measure a contact-sensitive specimen (like battery film), a vacuum plate helps anchor the workpiece to the plate surface without marring in order to acquire more stable measurements. Vacuum plates are available in packages as well as custom-made solutions from Mitutoyo.
Don’t Miss Out on the Mitutoyo Litematic Special Promotion
Download the Mitutoyo Litematic Special Promotion literature to learn more details on the discounted prices and the different type of Litematic units and vacuum packages available at 10% off until December 13, 2024.
