With a portfolio of more than 5,500 products, Mitutoyo has the capabilities to solve practically any metrology challenge. Explore our product offerings and find the measurement solution that’s ideally suited for your application.
Explore Our Product Groups
Coordinate Measuring Machines
Mitutoyo coordinate measuring machines are ideal for 3D measurement applications that require a high degree of accuracy. With advanced digital control, contact and non-contact sensors, and a wide range of sizes and designs, these CMMs enable faster, more accurate inspection and quality assurance.
Form Measurement
Whether you are measuring shape, roundness or surface roughness, the form measuring solutions from Mitutoyo can ascertain whether a complex shape meets your stated requirements. With both compact handheld instruments and high-precision floor models available, we can accommodate your form measurement needs.
Linear Encoders and DRO Systems
Mitutoyo produces a full line of digital scales, linear scales and DRO systems with shockproof, vibration-resistant and waterproof capabilities. These rugged systems offer unmatched measuring accuracy and intuitive user interfaces, making them ideal for practically any application.
Optical Measurement
The high-performance microscopes and profile projectors from Mitutoyo allow users to measure workpieces smaller than 100µ with greater precision and higher optical resolution. Mitutoyo produces optical measurement solutions with long working distance objectives and a wide variety of stage sizes to suit your application.
Sensor Systems
Mitutoyo sensor systems offer the utmost accuracy for contact and non-contact measurement applications, with accuracy rates as low as 0.5 mm. With one of the broadest portfolios of linear gages, 2- and 3-axis display units and laser scan micrometers, we offer sensory measurement solutions for workpieces of all types.
Small Tools and Data Management
Mitutoyo is your single destination for innovative, high-precision small tool instruments. Our portfolio includes thousands of solutions, including the highest-resolution handheld micrometer commercially available. In addition, our solutions enable automatic data transfer to SPC software, making accurate measurement easier than ever.
Test Equipment
The test equipment solutions from Mitutoyo deliver industry-leading performance for strength, ductility and wear resistance evaluation. With solutions designed for four major measurement types and fully automatic models available, our broad portfolio is all you need to keep workpieces within hardness tolerances.
Vision Measuring Systems
The vision measuring systems from Mitutoyo can bring fast, accurate and efficient 3D measurement to your applications. Their non-contact pattern recognition, measurement and edge detection capabilities provide accurate measurements in just seconds, allowing you to improve accuracy and throughput.
A Complete Metrology Solution
Mitutoyo supplies everything you need to make accurate, efficient measurement a seamless part of your regular process.
Parts List
If you are looking for a specific component for an existing Mitutoyo product, our comprehensive, searchable parts list has what you need.
Software
The metrology software solutions from Mitutoyo offer a more efficient way to model, measure, analyze and optimize your products.
Industry Solutions
Mitutoyo Custom Solutions Group
Are your metrology needs highly specialized? Not a problem. Find out how Mitutoyo can design the custom products, fixtures, accessories and software you need to ensure accurate measurement.
